my coverage in Canada
msabeysekera
Hi
I live in NB.  Plan  to travel to Ontario. My current plan -
5GB at 3G Speed ,Unlimited Canada-wide Talk, Unlimited International Text
Will my plan work in Ontario as it is  with no limitation? Or do I have purchase extra add-on
Advise appreciated
Regards
Manju
darlicious
@msabeysekera
Youre welcome! Come to the community anytime you have a question. We are always happy to help!
msabeysekera
Thx for your help
msabeysekera
Thx for ur help
darlicious
@msabeysekera
Your plan and all of your services are seamless and work anywhere in Canada as long as you can connect to a telus/bell tower. So there is the odd area you may not have service like a couple of spots in the mountains of bc or remote spots in Newfoundland and Labrador for example but otherwise everything works the same as at home in New Brunswick.
Meow
Absolutely - Yes. Your PM plan will work anywhere in Canada. No need for any add-ons.
MrSpock
@msabeysekera hi you are good to go anywhere in Canada have a great trip!!
