my cellphone data is off
Priest1
my cellphone data is off and i cannot turn it on.
k
CS_Agent
Customer Support Agent
I sent you a private message. You can view and reply to it by accessing this link:
slusagm
sound like it is a device only issue
make sure you disable Power Saver or Data Saver.   Also disable data limiter
hairbag1
@Priest1
Try rebooting cell. If that fails try network reset.
added…log in to your account using the app and look for Usage Breakdown to see if you still have data to use.
