08-27-2025 06:17 PM
08-28-2025 08:00 AM
Thank you for the escalation! The customer is in contact with an agent.
08-27-2025 06:30 PM
Yes I just did that. I cannot open my account since it is sending otp to my new number which is not active. Hopefully they can fix it from their end.
08-27-2025 06:27 PM
Did you use the PM app?
Ask PM to help. Since you cannot properly login, you won't be able to open the preferred Chatbot ticket. So, you will need to message them here: https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
https://productioncommunity.publicmobile.ca/t5/notes/privatenote
08-27-2025 06:22 PM
you must download the Public Mobile app to your cell to start the activation process. You must use a new, unused Public Mobile sim. You need an email address and a valid Cdn payment card.
