11-22-2019 07:40 PM - edited 01-05-2022 08:05 AM
will i be able to move my existing cell number to public mobile?
12-02-2019 03:04 PM
I just did this from Bell. Very easy. Either look at your old account online or phone your old provider. You'll need either your Account #, Phone Serial #, or one other number I forget. You just enter that along with your phone # you want to switch, and it does it for you. If you're with Rogers, Bell, etc. then your old plan will also automativally get cancelled (but I'd call them or look online to confirm)
11-23-2019 03:16 AM
@Raf414 wrote:Yes you can you need your account info provide it to public mobile
Specifically, it's the old carrier's account number that's usually needed.
11-23-2019 02:58 AM
11-22-2019 08:03 PM
@jamesd wrote:will i be able to move my existing cell number to public mobile?
@jamesd Yes, it's called porting your number. Activate you PM card and pick a temporary number. Once everything is setup including your selfserve account. Just sign in to your account and choose the change number option and then you will be able to setup the transfer of you number by providing the requested information.
11-22-2019 07:44 PM
Yes you can! Where is your service now? What phone are you using?
11-22-2019 07:41 PM - edited 11-22-2019 07:43 PM
@jamesd you should be able to! Don't cancel it, just set up public mobile and port your number. Don't forget a refferal code to get a 10$ credit on your new activation
