moto g5/moto g5 plus/other
TML2016
so i dropped by phone and the screen is broke.. ugh
wanted to get this phone... cant tell from anywhere if it will work with public mobile.. anybody able to verify? ive checked the compatibility websites but they can't confirm lte.
if it doesnt anybody have suggestions for the best budget phone in the $200 and $300 range?
13 REPLIES 13
I bought my Moto g5 plus in the States and it work perfectly well across Canada!
PBForMe
The Zenfone 3 Snapdragon 625 variant is a nice midrange phone, good battery life, dual sim, sdcard support and on Nougat for about 300 on amazon.
If you need even more battery life the Zenfone 3 Zoom has a crazy 5000mah battery for about 400 bucks on amazon as well.
skmkenn
From what I can see it should be compatible with both 3G/4G (HSPA) and LTE on Public Mobile's network.
TML2016
sorry should have asked.. you said the us and canadian version will work.. if i get the us version from amazon ill still check lte correct? i see that it will work on 3g for sure but the compatibility websites say it only might work on lte
TML2016
hmm okay cracked my old moto g phone... so guess ill pull the trigger on a refurbished moto g5 plus i found. thanks.
Both the US and Canadian versions will work.
TML2016
Are you able to verify which version you bought? im assuming the US?
skmkenn
If you purchase one from TELUS or Koodo it will work with Public Mobile even without needing to be unlocked.
I can confirm the moto g5 plus working with PM.
Be careful when you choose/where you buy it, because there is different versions in the States and elsewhere in the world...
Main difference is that no model has dual SIM AND compass... Need to choose one or the other. If you buy it from the States I would definitively choose the 64gb/4gb over the 32gb/2gb... The price difference isn't much and you would likely eventually need to buy a SD card anyways if you choose the 32gb...
Also, and updated version of the moto g5/g5 plus has been announced, you may want to wait a bit for the new one (or for a discount on the old ones).
will13am
Use this website to check phone band compatibility.
https://willmyphonework.net/
Shutdown
Any phone that works with telus should work with PM so any telus/koodo phone they are selling will work.
xCameron94x
If you want a stock Android experience, than the moto is the way to go. The moto g5 will work with PM
If you aren't too too picky and just want basics, BLU phones can be another option
Asus also makes good budget friendly phones in your price range, but they come with a lot of bloatware (or so I've heard)
