data
rhino1
MY data wont work on my new moto g 04 but works on my old samsung. I have tried options from youtube turning on data going through developer options and nothing works .My data worked at first and i recently added data twice but no go.I put my sim card back into my samsung and it workd there ok.Any thoughts.
Phil_Adelphus
rhino1
done that still dont work.when i click on an icon for the internet it comes back with we cant seem to find an internet connection.It just worked on the same site when i switched my sim card back to my old phone.
hi @rhino1
how long the data stops working?  check if you have setup a data limit, it can disable your data usage if your reached the limit.  Best to disable it completely
To disable the data limit on your Moto G, navigate to Settings > Network & internet > Mobile network > Data warning & limit, then toggle off the "Set data limit" switch.
