monthly data useage total
tx
Where can I see my data useage total for the month, other than adding it all up individually
thanks
@tx
I don’t think you can see the previous total month’s data.
Only the current data usage. You can go to the usage history and filter the dropdown menu to 60 days and you will have the amount of data use for that day and you need to add up all the days in that monthly unfortunately.
tx
Thanks I will check these out
@tx - best way to see what was used up within a month/30 day period would be to choose the DOWNLOAD option. It goes into an excel spreadsheet.
Note though, the data reflects only twice (in 2 separate buckets/batches) in a 24 hour period. So if you are looking for this morning's usage best to download it this evening, or even better tomorrow morning.
Install an app to track your ‘live’ usage so you can keep track. Public Mobile are 30 day plans (not monthly).
If you are android, try this one:
Data Witness app: https://play.google.com/store/apps/details?id=com.iwik.datawitnesspm&hl=en_CA&gl=US
I use this one myself and it gives me what I need from it.
You could also check out Data counter widget: https://play.google.com/store/apps/details?id=com.roysolberg.android.datacounter&hl=en_CA&gl=US
If you are an Apple user, I am sure there is a 30-day app that is available as well.
tx
I can see my current useage green bar yes, but If i wanted to see my previous monthly data useages, I can't see where it can give me those totals
mojorising
Log into your account and the information will be there on the main page with a green bar showing the total data being used currently.
https://myaccount.publicmobile.ca/
