04-05-2019 06:35 PM - edited 01-05-2022 04:10 AM
I was directed to ask moderators for help, so i sent 2 question to moderators, both of the moderators replies did not have a way for me to respond directly as far as i could figure out so i responded with a new question to the moderators with the answer to their question inside. is that the proper protocol here?
Joining Public
04-05-2019 06:45 PM
there you go, thanks
04-05-2019 06:43 PM
@danfrawls a écrit :yes i pressed the upper right envelope for messages and then i can see the messages but not all of it and i cannot reply, it seems i can not open the message to read all of it nor reply directly to it
Yes to open it you need to click on the subject line and you will see it.
04-05-2019 06:42 PM
not working, cant open full message nor respond directly
04-05-2019 06:42 PM
04-05-2019 06:40 PM
@danfrawls a écrit :I was directed to ask moderators for help, so i sent 2 question to moderators, both of the moderators replies did not have a way for me to respond directly as far as i could figure out so i responded with a new question to the moderators with the answer to their question inside. is that the proper protocol here?
When they reply you can click on the subject and it's a link to see the message and then you can answer it.
04-05-2019 06:38 PM
@danfrawls wrote:I was directed to ask moderators for help, so i sent 2 question to moderators, both of the moderators replies did not have a way for me to respond directly as far as i could figure out so i responded with a new question to the moderators with the answer to their question inside. is that the proper protocol here?
Did you use the upper right corner envelope icon to do the back and forth with the moderators? Or did you get an email and try to respond to that?
04-05-2019 06:37 PM
@danfrawls what is your questions then?
