01-07-2022 12:39 PM
Hello,
I ve just purchased an add on to be able to call France and every time I dial a number I have this message saying that
Your call cannot be completed as dialed
The number is
0033 +4.50.10.22.43
it is a regular number (not a toll free)
I ve tried several other numbers and it is the same result.
What should I do?
Thanks for your help,
Emma
01-07-2022 01:03 PM
You're very welcome @Tofino ! All the best, and now happy international calling to you! 🙂
01-07-2022 01:02 PM
Thanks so much it works perfectly by adding the +sign
amazing!!
Thanks 0PX9O4
01-07-2022 01:00 PM - edited 01-07-2022 01:01 PM
The usage of 011 was relevant in the era of landline phones in North America (they did not have a "+" key), but the international standard of using the "+" sign is the better practice, and is the only guaranteed way to bypass any default formatting settings on your phone app.
01-07-2022 12:59 PM
@Tofino : There are a couple parts to all this international dialing.
1. Use either 011 or + to "get out to international".
2. If the other end has leading zeros in their numbers then drop them.
01-07-2022 12:56 PM
The error you are receiving has to do with the number being badly formatted. In addition, I can confirm that the number you have provided is valid, as per fone finder: http://www.fonefinder.net/findint.php?intlnum=33450102243&intlquery=Search+by+Number&intlname=
So the most likely scenario is that your "phone" app is configured to interfere with the formatting of phone numbers by default. Usually, this can be overridden by using the "+" sign. You will not be able to call an international number by just putting it in without a prefix, so "33450102243" will not work.
TLDR; try calling +33450102243 and share your results here.
01-07-2022 12:53 PM
yes sorry that was confusing that is what I used
33450102243 or 0033450102243
same answer
thanks
01-07-2022 12:52 PM - edited 01-07-2022 01:34 PM
EXAMPLE: 01133xxxxxxxx
you can try reseat the SIM card and Make sure your phone is off before removing your SIM card,
1. power off your device
2. take out the SIM card,
3. waiting a 1 minute,
4. put it back and power on,
5. toggling airplane mode off/on,
and try manually selecting network "3G ONLY" or WCDMA only,
for iPhone visit Here link
or Here link
for android visit Here link ,
and do Rebooting your phone ,This is quick and simple,to refreshing your network,
*what is meant by rebooting the device turn off and turn it back on.
01-07-2022 12:46 PM
Hi Emma,
The plus sign cannot be used in addition to "00". You should just dial +33450102243 from your phone.
