making and receiving calls not working
gosselin1
cant make calls or receive calls
edited by computergeek541:  changed category label as discussion isn't related to Community
2 REPLIES 2
hi @gosselin1
what phone do you have?
Telus is refarming all of their 850 to 10 MHz LTE B5 in their markets, mainly BC, AB, Windsor, Ottawa, GTA area Montreal, Quebec City.   Bell has not done this, so it won't affect area that has Bell networks which Telus/PM use
If you phone has VoLTE and is compatible with PM VoLTE, you shouldn't be impacted at all.  Check here:
https://www.publicmobile.ca/en/get-help/articles/volte
But if your phone is not not on PM's VoLTE whitelist, and if your phone has only 850 Band 5 on the phone but lacks 1900 Mhz, if your phone were bought from another country, or an imported model, then you might be impacted with no 3G voice service at all
On the other hand,  if the phone has 1900 Mhz,  or it is a Canadian/US model,  it likely won't be impacted as much but the voice calls quality might still degraded.
https://www.publicmobile.ca/en/get-help/articles/850-turndown
CSA_PM
Customer Support Agent
Hello there.
I sent you a private message.
You can view and reply to it by accessing this link:
