lost my phone
jeffmacroy
how can I start using another SIM if I cannot access the old phone (its gone) no other access to account other than this laptop which doesnt have that email logged in .....2 step verification is a nightmare
thx
PS I already suspended my service on here as well so dont need help with that just the sim
darlicious
@jeffmacroy
Contact customer support to perform the sim swap for you. Have your autopay card handy to help answer the extra verification questions you will be asked by the CSA.
Keep an eye on the envelope icon next to your avatar at the top right corner of your screen for a little number to pop up indicating a reply from a CSA. Responding promptly will speed up service times but expect a reply within an hour.
To pre-verify your account in your private messages only include your full name, address, email, phone # and 4 digit acct pin #
HALIMACS
@jeffmacroy
Contact a Customer Support Agent
  1. Use the ticketing system for a faster response time. Click here and type Customer Support Agent, then select Contact Us, then select Other (or the topic that more closely matches your request).  Click the result which states Click here to submit a ticket and follow the prompts,  or,
  2. Send a private message to the Customer Support Agent by clicking here  You’ll need to be logged into your Community account for the link to work.
@jeffmacroy   Which mail service you are using?  GMail? Yahoo?
JL9
 Do you already have brand new/replacement sim?
dust2dust
If you have no webmail or client access to that email inbox then all you can do is contact the support people.
