11-18-2016 06:59 PM - edited 01-05-2022 12:37 AM
Do the long distances minutes round to the nearest minutes or do they go by seconds. For example if I just pick up a call for 1 second then disconnect it will that round up to 1 minute? or only count as 1 second towards my minutes if I were to have it.
Service
11-19-2016 04:15 AM
Think about this for a minute and you will see why your comment is so funny
If it rounds to nearest minute you are always losing the final minute
So to calculate simply take your number of calls and divide by 2
You do not need a stopwatch at all
Want to maximize use?
Make 1 call that is 400 minutes long
11-18-2016 07:22 PM - edited 11-18-2016 07:22 PM
Rounded to the full minute. So for example a 5 second all costs 1 minute from the add on. A 55 second call costs 1 minute from the add on.
11-18-2016 07:19 PM
Sounds like to maximize usage have a stopwatch ready!!!
11-18-2016 07:01 PM
They round to nearest whole minute, but minimum is 1.
