long distance minutes add on
yo2
Hi I paid for 1000 minutes long distance and it didnt get put on to my plan, I thought it didnt go through so I did it again. Now I see on my plan U.S. roaming add-on but I never purchased it. Any way to get a refund for the extra add-on and to change the add-on to the one I actually purchased?
Thank you
@yo2
users themselves cannot change an already-purchased add-on.
But customer support agents will cancel the undesired add on (presuming it was not used) and place the amount of the purchase price into your available funds towards the add on you desire.
To contact a Customer Support Agent, send a private message to them by clicking here
You’ll need to be logged into your Community account for the link to work.
 Then watch for their response in your Community private mailbox which will be indicated by a number on the small envelope icon to the left of your Community avatar.
Links have been provided.
Click on the little spinner refresh icons near the shop add-ons button to make sure you're seeing updated info.
yo2
it seems that I mistakenly purchased the roaming instead of the minutes, it only shows up that I purchased it once but my credit card was charged both times I tried. Any way to change the add-on?
hairbag1
@yo2
best is to contact CSA and they can fix this small error for you...but don't goof it up again, y'hear !  🤣
@yo2
Check your My Account's Transaction log to confirm what you have purchased.
https://myaccount.publicmobile.ca/en/account/payment/payment-history
PM is a prepaid provider and usually do not provide refund.  However, no worry, if it is an honest mistake, they would usually take care of  it.  Please open ticket by messaging them here:
