login problem
Tomokon
Hi,
I am currently out of country and can not login my account since when I try to login I need to put 6 digit one time code which sent to my cellphone - and can not recieve this number (because of out of country). How I can solve this problem?  Can you set up to send this code to my account email address.?
Thank you.
Tomoko
2 REPLIES 2
HI @Tomokon
just in case you don't see the option for send email , you will have to ask support agent to help, Message them:
The first thing to try would be to start logging into your account and after using your username and password, select the didn't get code/resend code button.  From there, select the e-mail option.
