locked out
11-14-2019 08:38 PM - edited 01-05-2022 07:59 AM
after having been locked out and trying to get a new password, I am still getting stuck on the security question. If I enter the security quesiton as I remember, and click on continue, the next screen informs that the answer to the security question was wrong, although I never was given a chance to enter an answr
My Account
11-14-2019 09:38 PM
@paul-public-345 , I think you can get locked out for too many failed attempts. I suggest just asking for moderator team assistance on this one. The moderator team can be reached via private message using smartforms which is initiated by clicking on the ? on the lower right corner of the webpage or try using this link. The guided process will facilitate documentation of the issue or concern and the required resolution which will be submitted to the moderator team. Refer to this announcement link for additional details on smartforms and the ticketing system for moderator team interactions. If use of smartform brings no joy, then use the following direct link to private message the moderator team. Refer to the following knowledge base article for additional information on the moderator team.
11-14-2019 09:17 PM
Also, the security question is case sensitive I believe so try with or without upper case letters.
11-14-2019 09:02 PM
Website is finicky. Maybe try clearing cache, different website or incognito mode. Chrome incognito works well.
If still not working, you may need to contact moderator.
11-14-2019 08:44 PM
@paul-public-345 Hit the ? mark type reset password and try resetting your password with that link to see if it makes a difference.
