lg k30
01-15-2020 03:12 PM - edited 01-05-2022 09:02 AM
hi i would like to know if a lg k30 (2019) is compatible with your services thanks
Joining Public
03-17-2020 02:26 PM - edited 03-17-2020 02:26 PM
@Victoriaheglin If you already have the phone, it works, but is light on 4g LTE bands. So, you can talk , text everywhere ( once data is enabled) and use 3g data. But in areas where there aren't 3g and 4g LTE band 7 2600 data, you will not have any data (be able to surf the internet).
03-17-2020 02:20 PM
Is lg k30 compatible with you
01-15-2020 03:41 PM - edited 01-15-2020 03:43 PM
@ChuckYeah wrote:@bigbear87 IF you haven't bought it yet. It may not be a great fit.
I don't know much about this stuff but it is missing some of the recommended Lte bands. 3G looks ok though. One of the more technical members can tell you better if it's worth the risk.
This is the LG K30 from GSMarena.com.
I agree, if this is the version in question, don't buy it if you haven't already. Only Band 7 is a match for Telus/PM frequencies. So vry limited LTE data coverage.
Band 4 is the most used LTE band in Canada, then there's also 12, 17, 5...
(On the phone, so I don't have easy access to my preferred links on this, sorry.)
01-15-2020 03:35 PM
I see @ShawnC13 is online.
01-15-2020 03:32 PM
01-15-2020 03:30 PM
Telus has that particular model. https://www.whistleout.ca/CellPhones/Carriers/Telus/Phones/LG/LG-K30-2019 . Since this is a TELUS company. It should be compatible.
@bigbear87 wrote:hi i would like to know if a lg k30 (2019) is compatible with your services thanks
01-15-2020 03:20 PM
Use this link https://publicmobile.ca/en/on/get-started scroll down to find out if your phone is compatible. And test your phone.
