length of time to switch from koodo prepaid to pm
Dinsdalej
Hello just wondering how long it take for a number to get moved from koodo prepaid to pm
thanks
7 REPLIES 7
@Dinsdalej
If you wish to transfer an existing numbering from Koodo Prepaid, you will need to first complete your activation with a new number, then reach out to our Customer Support Agents in order to transfer your existing number to Public Mobile.
How to transfer your Phone Number (publicmobile.ca)
but try this Make sure the old SIM card in your phone when you're Transfer your number. You should get a SMS message from your old carrier asking to confirm if you would like to Transfer your number. Your reply should be: YES.
The confirmation message can take a few minutes to come in. You have 90 minutes from the time of request.
if you stuck with Transferring your old Phone Number, or is not complete processing
Here’s how to contact Customer Support Agent by CS_Agent,
  • you need to send a private message to Customer Support Agent by CS_Agent, by Click Here link
  • phone number,
  • which carrier,
  • Customer Support Agent by CS_Agent, will Response to your inbox by private message
  • During business hours, we strive to answer customer messages swiftly. You will often get an answer within an hour. During peak periods, you may need to wait up to 48 hours.Customer Support Agents are available:
    • Monday to Sunday: 6 AM to 10 PM EST
    • Note: Public Mobile No Support by phone call or Email.. only by CS_Agentprivate message..
  • Check your private message inbox (click on the envelope top right of your screen)
Good Luck and your welcome to Public Mobile
you will be very happy...with a Fabulous Service.
Twillingater
I have switched 3 phones now the first one took about 30 hrs next 2 were switched within 30 mins.
Just a little patience is required sometimes.
@Dinsdalej
Koodo prepaid and public mobile share the same back end system. As a result the koodo prepaid phone number does not get ported in to public mobile in the traditional sense but rather gets transferred between accounts from the koodo account to the new pm account.
  1. Activate the pm sim card and choose a temporary pm phone number.
  2. Ensure all the pm services are working on the pm sim card.
  3. Contact customer support to complete the number transfer supplying the CSA with your koodo phone #, account # and the full name on the koodo account.
  4. Be sure to put the koodo sim card back in the phone to reply YES to the PAT (porting authorization text) within 90 minutes of receiving it.
  5. Once you reply to the text you can put the pm sim card back in your phone. The number transfer will complete in a few minutes to maximum of two hours (depending on CSA workload.)
  6. Completing the initial activation earlier in the day will ensure that customer support can complete your request in a timely as there is no real support overnight to complete the number transfer.
@Dinsdalej
It also depends if replied to the SMS text with the Koodo SIM in the phone. Once you replied with YES, it should be within a minute.
thanks
@Dinsdalej
Porting from Koodo:
If your switching from Koodo postpaid your can port-in your number during sim activation. Just have your Koodo account number, name on the Koodo account and Koodo number ready and enter it when choosing your number.
If it's Koodo prepaid then you need to click this link and type in “port request” to be put in touch with a Customer Support Agent (CSA). Include the Koodo info above.
If you just ported your phone number from another cell provider it could take a few hours to complete the port.
Using the other cell provider's SIM you should be still receiving calls on it, until the port completes.
Incoming calls are usually the last to port over.
See helpful info. here: https://www.publicmobile.ca/en/bc/get-help/articles/port-fraud-protection
Dinsdalej
sound good just trying to time out when i should send in the request as the user is out of town thanks for info
LeePublic
@Dinsdalej It could take a couple of minutes to a couple of hours for the number to port completely. When did you join PM?
