09-10-2025
05:50 PM
09-10-2025
10:01 PM
computergeek541
how do i close public mobile service on stolen phone, switch the prepaid year service to new phone or buy new prepaid service, keep old phone number and contacts pictures etc.???
09-10-2025 06:23 PM
If your phone is stolen most likely you lost all contacts, pictures, videos, songs, etc. IF YOU kept them on the phone. If you kept them on a 'cloud' you will be able to access them as you establish new phone and service.
If you kept somewhere IMEI of your phone you should report it immediately as stolen so nobody can use it. They can still use your physical SIM unless you get new SIM quickly and transfer number to new SIM. I believe you can even borrow friend's phone just to do phone number transfer from stolen SIM to new SIM.
You do not have to close PM account. Just transfer SIM number from stolen to new SIM. Then deal with rendering stolen phone useless...
09-10-2025 05:53 PM
you don't have to close the current PM account. Just get a Public Mobile sim card from Telus or Koodo or MobileKlink for $10 (or Amazon for $5)
then you can try to login My Account and update the sim card number. Use email to receive 2FA so you can login
or you can just ask PM to help to update the sim card number.
Since you cannot properly login, you won't be able to open the preferred Chatbot ticket. So, you will need to message them here:
