07-02-2017 06:46 PM - edited 01-05-2022 02:20 AM
when I was still on FM I use somewhere between 750 mb to 1.5 GB of data, then at the end of the month, my bandwith usage would resets back to zero. Will PM be also resetting my data usage back to zero next month or is it every 90 days?
07-02-2017 07:23 PM
07-02-2017 07:02 PM
thanks for the reply. So far I've only used about 559.8 MB on my phone and I don't really need a data tracker app since I can track my data usage in the oxygen OS on my OP3T.
07-02-2017 06:54 PM
It will be every 90 days. If you want you can download data tracking apps, or use your stock data trackers on android/iOS to keep track. My Data Manager is good with tracking 90 day plans from reviews i've seen on the fourms here
