07-03-2018 01:25 PM - edited 01-04-2022 06:21 PM
hi
so I just joined and wondering how long it takes for the new sim card to become active and my old plan to stop so that I can switch. and is there anything that lets me know its all done.
thanks for your help in advance
Joining Public
12-11-2019 08:14 AM
Welcome to Public Mobile and participating here.
You may not have noticed the checkmark on this thread. That means whoever started the thread decided that one of the posts was the answer to their question. So after that, unless someone has new helpful relevant information to add...it's kinda pointless to add to it.
Then there's the date of the thread. You revived a year or so old thread.
12-11-2019
08:06 AM
12-12-2019
12:39 AM
computergeek541
try to reactivate your account with bell and once that active you can port in to Public Mobile and it takes 5-7 minutes to register yourself to them.
edited by computergeek541: removed content from message that is not allowed
12-11-2019 08:04 AM
You need to have your current number should be active, as long as everyhring ok you will be start using the services.
12-11-2019 08:03 AM
Immediately - in last 1 week i did 2 activations for Public Mobile and they are awesome. My wife using this since last 3 years and no problem in the data/call so far.
07-24-2018 07:50 PM
If you cancelled the account before the port it won’t be able to be carried over. Contact a moderator to change password on your account here so you can log in.
07-24-2018 07:45 PM
Canceled my bell account and now i have no service what so ever..... no calls and no txt messages.....
help i've tried changing my password i'm stuck
07-03-2018 04:22 PM
hey thanks for the info that was great info
07-03-2018 01:43 PM
@chickenfarmer, did you sign up the new account with a number port at the same time? If you obtained a new number, then the service will work completely right away. If a number port is involved, the incoming calls and text will not work until the port is complete. The calls and text would continue to be sent to the old carrier prior to the number port completing. Generally, a wireless number port from a competing carrier should complete inside of a couple of hours.
07-03-2018 01:31 PM
Did you buy from Walmart or public mobile? The sim card if bought from Walmart or wow mobile for example should become active immediately once you have enough funds on it to cover your account. If you port your number over it could work in as little as 30 minutes and as long as a couple days. Depends if you are porting a voip or mobile phone number. Welcome to the community!
