is pm website down now
chch518
kaytus
@chch518 it is kind of up, just very slow.  You can try multiple times and you might be able to get in.
But I will do the change after the suite is stable.
Patchio
@chch518
Yes, the My Account and My Rewards website are unavailable due to unannounced maintenance work by PM.
See here:
https://productioncommunity.publicmobile.ca/t5/Get-Support/Sign-in/m-p/898152/highlight/true#M613625
There have been at least five other threads about this ongoing issue since this morning
@FlutteringBy @chch518   problem since early this morning
But if you are in no rush, I do not suggest you to login and do anything serious  at this time (like plan change or payment) just in case the timeout issue and you don't know if the action was completed
FlutteringBy
It must be....I can't get in either....😐...
