04-15-2020 03:27 PM - edited 01-05-2022 10:23 AM
A friend is giving me his iphone8 does he have to clear his apple Id off it for it to work for me? I've never owned an apple product.
04-15-2020 03:59 PM
@carlaspapa Your friend will also need to remove the phone from his list of registered devices in his iCloud account. https://support.apple.com/en-gb/HT201351
04-15-2020 03:52 PM
Here's 4 articles on activation and porting and the Refer a friend reward if required:
1. What you require to activate https://www.publicmobile.ca/en/bc/get-help/articles/what-you-need-to-activate
2.How to activate https://www.publicmobile.ca/en/bc/get-help/articles/activation-account-set-up
3.How to port https://www.publicmobile.ca/en/bc/get-help/articles/choose-your-phone-number
4. Refer a friend https://www.publicmobile.ca/en/on/get-help/articles/the-refer-a-friend-reward
Welcome to PM. Stay safe.
04-15-2020 03:44 PM
@carlaspapa that's great it's a fine phone you will enjoy it I know I did
04-15-2020 03:40 PM
Thanks everybody! I get it on Friday so I'll have lots of questions then.
04-15-2020 03:37 PM
@carlaspapa Make sure your friend clears their Apple it before applying and factory reset the phone beforeactivsting your own. Stay safe.
04-15-2020 03:35 PM
@carlaspapa once you get the phone and go through the set up you do it then
04-15-2020 03:34 PM
@carlaspapa wrote:How do I get an apple Id ?
It is just an account. Create one.
04-15-2020 03:34 PM
04-15-2020 03:33 PM
04-15-2020 03:30 PM
@carlaspapa wrote:A friend is giving me his iphone8 does he have to clear his apple Id off it for it to work for me? I've never owned an apple product.
The phone will need to be unlocked, the ID will need to be cleared. This goes for any apple product you purchase otherwise you could have access to your friend's personal info, including contacts and apple music.
04-15-2020 03:29 PM
@carlaspapa hi yes you will need your own apple id he needs to do a reset and wipe the phone
