03-17-2024 09:47 PM - last edited on 03-18-2024 12:17 AM by computergeek541
hello how do i get my iphone 12 pro max to connect. I transfered today, it says active on my public mobile app, but I have no service still.
03-18-2024 08:46 AM
Thank you this helped! Though I did not see "Public Mobile sim card" But I did notice I had two of the same numbers listed Primary and Business. Under the Business there was a button that said Delete eSim. So I figured that must be the correct one. So I turned off what was listed as primary and on the Business and that worked! Writing it here in case that extra info helps someone else.
03-18-2024 12:46 AM
Try to connect with the help of laptop.
03-17-2024 10:07 PM
Hey @sundaymorningxo
If you just transferred today, did you reboot the phone? Have you tried your SIM card in another phone? If it works in another phone, just shut down yours before putting it back in. Then restart it again. If that doesn't work, perhaps you may have used your phone with a different service provider? If so, try doing a network reset and reboot the phone. You may lose your saved wifi locations and possibly your bluetooth saved connections but those are easy to restore.
03-17-2024 09:51 PM
esim or physical sim ?
if you have physical, did you try it on another phone?
if you have esim, check Settings->Cellular , is the Public Mobile sim card there? if it is, set it Primary and "Turn on this line"
if that does not help, you will need CS agent to help, please submit a ticket with CS Agent using this Chatbot link: https://widget.telus.tiia.ai/publicmobile/publicmobile.html Type the question "Submit ticket", Then click the following in order: "Contact Us" , "Other", "Log In".
If any issue with ticket submission, you can submit by direct message:
