iphone Xs suddenly can't make calls
marti713
Rings once when calling out and says call failed.  Sometimes I see primary and travel lines on top. I f I choose primary the call usually works.   How can I get rid of this new "travel" line? Where did it come from?
I also went to setting,cellular and I see 2 primary lines (only have one sim), turned off 2nd one and it asks if I want o DELETE the sim so I turned it back on
2 REPLIES 2
marti713
I did about 1.5 years ago but never had this issue until now
DennyCrane
Did you download a travel esim? You can delete the second from the sim menu.
