iphone XR unlock issue
dummytoto
Had to switch from my broken iphone 7+ to my new Iphone XR which is supposed to be unlocked (bought fully unlocked on amazon). Just inserted my sim card in my new Iphone XR and receive the message that sim card is not compatible with the activation server. Insert a sim card compatible or ask operator to unlock the iphone.  Do not understand what it means exactly? Thank you for your help.
13 REPLIES 13
dummytoto
the phone was still locked as per an Apple tech guy.
SO I returned the "fully unlocked "phone as per Amazon decription!
@dummytoto wrote:
Just checked: Phone is not blacklisted...
@dummytoto  - just to confirm it is not for sure locked...
To check if your iPhone is locked, open Settings and tap General -> About -> Carrier Lock.
If it is locked contact the seller to have it unlocked for you, or return it.
If it is not locked, try one or more of the below:
*turn off your phone, leave off for a few minutes, then reboot
*removing your SIM, then reinserting it
*go into airplane mode, then going back to regular mode
*reset network settings on your device
*try someone else's working SIM card into the xr phone to see if it works; Public Mobile or otherwise.
dummytoto
pkaraa
Recently we saw another case of blacklisted device sold over Amazon. So scammers are getting smart nowadays. Return it if possible and try to get one from Public Mobile site. You might find a good deal here too.
@dummytoto wrote:
return the phone is not what I want to do...
@dummytoto
the can do exchange for you also for Free,, so why you like to keep device is not working right.
@dummytoto  a écrit :
does not work! still message saying sim is not compatible!
Try another active SIM from any provider.
i just worry your phone is blacklisted.. someone post yesterday, he got from Amazon, blacklisted phone
dummytoto
@dummytoto
device has a issue, you can return to Amazon for Free.
dummytoto
What was the exact message?
your phone could be carrier locked.  Since you got it from Amazon, you cannot tell which carrier this phone came from, and you likely cannot get the unlock code for free
I suggest you to make a ticket with Amazon and return it for a full refund before it is too late
Your other route is to pay around $20 US for an unlock code.
@dummytoto
all unlocked device iphone is will working with Public Mobile.
maybe that device has a issue, you can return to amazon for Free.
Public Mobile uses the following frequency bands:
  • 4G LTE and LTE Advanced: 700 MHz, 850 MHz, 1900 MHz and 2100 MHz downlink and 1700 MHz uplink (AWS).
  • HSPA: 850 MHz, 1900 MHz (UMTS).
here website you can check it out any device  Will Apple iPhone Xr work in Canada
@dummytoto
try to do Factory Reset,
iPhone Xr Hard Reset / Factory Reset
