08-02-2026 09:24 AM
Hi @hairbag1 I had the same issue this morning and went through the steps to purchase a new eSIM and install in my iPhone, however I don't think it ended up being free as it asked for payment info for the $5 purchase. Is there way to get that refunded?
08-02-2026 09:26 AM - edited 08-02-2026 09:27 AM
hi @BassFisher
it is only free if you got your last eSIM over 15 days ago. If it is less, you need to pay for $5
but if there was technical issue and you need it to resolve your issue, PM agent might be able to give you back a credit. Check with them
submit a ticket with CS Agent using Chatbot here:
Type the question "Ticket", Then click the following in order: "Account Management" , "Log In".
(If unable to receive 2FA SMS, click "Didn't Receive Code" or "Resend Code" and Select "Send Email")
If any issue with ticket submission, you can submit ticket by direct message:
