12-06-2021 02:18 PM - edited 01-04-2022 04:55 AM
hello,
the intercom system of my apartment building stops working for me after I switched to Public Mobile from Koodo prepaid. I am supposed to receive a phone call when somebody at the entrance presses a button. But instead the call is redirected to my voicemail without ringing on my cell phone.
I have checked possible causes from my side, such as blocked list, no disturb mode, call forwarding, etc...
Anyone might have a clue? thanks a lot.
12-06-2021 03:54 PM
@siaodani wrote:hello,
I found this thread on Koodo. Looks a lot like your issue. Try the "solution" in there to see if it will solve your problem.
Building intercom not connecting | Koodo Community (koodomobile.com)
12-06-2021 03:33 PM
I get other incoming calls without problem
I just not getting the calls from the Intercom.
thank you
12-06-2021 03:30 PM
a couple of days ago
PM agent confirms that the number transfer is complete.
no service with Koodo sim
thank you 🙂
12-06-2021 02:47 PM
12-06-2021 02:46 PM
@siaodani you get other incoming calls without problem? you just just not getting the calls from the Intercom?
12-06-2021 02:45 PM
it has been a couple of days since I switched to Public mobile
I didn't really get what you meant by your second point tho..
thx a lot cheers
12-06-2021 02:43 PM
yes
no
thank you 🙂
12-06-2021 02:38 PM - edited 12-06-2021 02:39 PM
you can try reseat the SIM card and Make sure your phone is off before removing your SIM card,
1. power off your device
2. take out the SIM card,
3. waiting a 1 minute,
4. put it back and power on,
5. toggling airplane mode off/on,
Go to Settings > General > Reset > Reset Network Settings.
This also resets Wi-Fi networks and passwords,
or visit Here link,
click Here link,
or visit Here link,
and go Changing APN Settings On Android device
click Here link,
Ensure you have the correct APN settings by visit Here link,
and try manually selecting network "3G ONLY" or WCDMA only,
for iPhone visit Here link
or Here link
for android visit Here link ,
and do Rebooting your phone ,This is quick and simple,to refreshing your network,
*what is mean for Rebooting the phone means to turn off your phone and turn it back on again.
try to check update your device,
you can try to test your SIM card in another device to you know the issue from SIM card network or your device issue.
do you get a SMS message from your old carrier asking to confirm if you would like to Transfer your number. Your reply should be: YES.
if you can't fix it maybe you stuck with Transferring your old Phone Number,
Here’s how to contact Customer Support Agent by CS_Agent,
12-06-2021 02:31 PM
Just to summarize the replies.
Did you recently port your Koodo number to PM?
If yes does your PM service provide you with inbound and outbound calls...other than your intercom service?
If no your port might not be complete and you have split services.
Did you respond to Koodo's text to confirm the port out was ok to Do?
Did you receive an email from PM to say port was complete?
Do you have any service if you put your Koodo Sim back in your phone?
12-06-2021 02:23 PM
@siaodani how long you have requested porting? Was it within a day? or 2 days?
If so, wait couple more days and it might fixed itself. Some systems, like intercom or other VoIP apps need more time to find out your number is ported away
or if you actually got the intercom on our PM Voicemail , then try changing to 3G only and see
12-06-2021 02:20 PM
@siaodani : Are you otherwise getting incoming calls? Does your old Koodo SIM still work?
