06-11-2019 06:45 PM - edited 01-05-2022 05:20 AM
I registered and actived, my current phone is Moto G6 dual sim unlocked working fine, I still have my Samsung s7edge from Rogers and the unlock code, can I use my Galaxy s7edge and unlock it with same sim card?
Thanks in advance.......Don
Joining Public
06-11-2019 07:11 PM
Thanks
06-11-2019 07:09 PM
@robodonster65Do read up on the manual for your dual SIM phone..as on some phones some slots can do certain things while the others can't. As long as both phones are unlocked you can swap to your heart content.
06-11-2019 07:08 PM
lots of people do!
06-11-2019 07:08 PM
Thank you
06-11-2019 07:06 PM
@robodonster65 wrote:So I should be able to switch between my Moto G6 and Galaxy s7edge back and forth?
You can use your sim card in any UNLOCKED and compatible with public mobile phone you want with no problem.
06-11-2019 07:03 PM
06-11-2019 07:01 PM
No I don't as I have my unlock code from Rogers and it worked with freedome mobile!
06-11-2019 06:48 PM - edited 06-11-2019 06:50 PM
Can't see any reason why you couldn't use that phone
06-11-2019 06:48 PM
@robodonster65 wrote:I registered and actived, my current phone is Moto G6 dual sim unlocked working fine, I still have my Samsung s7edge from Rogers and the unlock code, can I use my Galaxy s7edge and unlock it with same sim card?
Do you need to unlock your phone Samsung?
