incomplete porting from Virgin
ryanelden
@CS_Agent  can anyone help with an incomplete number/account porting from Virgin?
I can send/receive texts, and phone out but any incoming calls are going to my old phone/sim card.
This is duplicate thread. IGNORE and go here https://productioncommunity.publicmobile.ca/t5/Getting-Started/incomplete-porting-from-Virgin/m-p/23...
will13am
Please contact the moderator team to look into the incomplete port.  The moderator team can be reached via private message using this link.  Refer to the following knowledge base link for information on contacting the moderator team.
nrg_svr
Just give it a bit more time I think... it's in progress by the sounds of it! Unless you did this yesterday or something like that.
