Is Canada wide calling really Canada wide?
04-30-2018 03:24 PM - edited 01-04-2022 04:12 PM
There is a confusing disclaimer on the Canada wide calling plan that reads:
"Includes outgoing calls you make anywhere in Canada to a number with an area code in the same province, and incoming calls you receive while you are in your home province. A long distance talk add-on is required to receive incoming calls while you are outside your home province."
Is this a mistake because I thought Canada wide meant that there is no home province and you can call and recieve calls anywhere in Canada without additional charges. Is this an error ?
04-30-2018 04:29 PM
As from the earlier illustrations, you need to match the footnote numbers up with the conditions. Since a Canada-wide plan would not have the corresponding footnoted number in the plan description, such a condition does not apply to that plan.
04-30-2018 03:33 PM - edited 04-30-2018 03:37 PM
@apper_on it's confusing, but you'll notice there are no note numbers beside the Canada-wide calling on the left. Hence, that point #2 does not apply to this plan.
EDIT: a picture is worth a thousand words. Notice no superscript "2" beside the Canada-wide calling:
But if we look at a plan that has Pronvince-Wide talk, you'll see the "2" appears next to it, meaning that note applies to it:
04-30-2018 03:31 PM
@apper_on, That sounds like the description for provincial calling plan. The Canada wide plan lets you call to anywhere in Canada from anywhere in Canada, and receive calls while you are anywhere in Canada..
04-30-2018 03:31 PM
@apper_on wrote:There is a confusing disclaimer on the Canada wide calling plan that reads:
That sounds like the description for province wide calling. Canada wide you can make calls within Canada and receive calls from anywhere without the need for any addons
