imessages
12-27-2019 12:08 PM - edited 01-05-2022 08:43 AM
12-30-2019 04:38 PM
@sandalwood wrote:It appears that SMS is NOT turned on by default on iPhones. I have a iphone and have missed imessages from others if my data is off or wifi is off. I have had to ask several people to turn on SMS in the imessages settings or send as a text. Not sure why default would be off. With unlimited text pretty much on all plans anyway .Why people use imessage is a mystery to me.
Exactly - ESPECIALLY if it uses data to send/receive them!
12-30-2019 04:29 PM
12-29-2019 11:27 AM
Thanks for this info... my daughter has an iPhone and I have a Samsung... she is always telling me she can't send something to me because our devices are not compatible... now I can tell her different...
12-27-2019 02:30 PM
@pmmobile wrote:@stoneheadFYI: From experience, non-iPhone users will not receive messages if you use iMessages to send them messages because it is different from regular sms
There is an option to enable "send as SMS" in the settings. Obviously you'll need to have the recipient's phone number for this.
12-27-2019 02:26 PM
12-27-2019 02:23 PM
Unlike SMS using carrier services, iMessage is sent through Apple's servers and is not recorded as carrier SMS usage. If you do not have a Wi-Fi connection, data usage will be recorded.
12-27-2019 12:18 PM
@stonehead wrote:how come imessages are not saved or logged in under my view my usage?
@stonehead Because iMessage uses WiFi or data when sending texts to other iMessage users.
12-27-2019 12:12 PM
They are probably listed as a data event and have some amount of data used unless on wifi. As for saved are you looking to see the actual message sent or received?
