im having trouble putting minutes
Tyonne79
I cant put minutes on my phone
@Vexcoustomer login to your self serve and click the "plans and add-ons" tab and select the $5/500 min Canada wide to reactivate your calling min
@Vexcoustomer wrote:
I put $20 dollars credit on my phone but I still can't make or receive calls
Having credit on your accoount doesn't allow phone calls. There are no pay-per-use charges at Public Mobile. You'll need to purchase a long distance minutes (that can also be used for loca calls) add-on.
Vexcoustomer
hairbag1
Make sure you have $$ in Available Funds, then Purchase Add-ons. Select the add-on you wanted.
RossN
@Tyonne79 hi buying an add on is a 2 step process first you put the money in your account and then go back and buy your add on
