01-09-2018 01:50 PM - edited 01-05-2022 03:53 AM
01-09-2018 03:43 PM
you're correct. I didn't know I could do those options.
01-09-2018 03:21 PM
@smp99 wrote:I don't think PM has *611 support service. They may have it when you are roaming in the States but that's it. That's why we have this community to deal with issues, not 611
i am talking about 611 self serve by daling 611 and enter the 4 digit pin,
01-09-2018 03:17 PM
01-09-2018 02:03 PM
@wetcoaster wrote:I have no way of verifying this but since *611 is communication with the provider and is not counted as talk you should be able to connect to the menue.
Be aware that you need a talk base plan if you intend to add a talk add-on.
if someone have data only plan can also verfy if hi can call 611
01-09-2018 01:57 PM
