01-11-2021 12:13 PM - edited 01-05-2022 04:49 PM
Hi everyone. I have a iPhoneXs Max and the data only works when I shut the phone off and turn it back on again. Everything works fine with wifi but when I leave home and am mobile, it shows LTE in the corner but I can’t browse the web. If I do a hard shut-off and turn it back on again (while not near wifi) it works. I’ve looked at phone settings but don’t see anything odd. For the cost of an iphone - I shouldn’t have to turn off/on to access data while mobile! Any help appreciated! Thanks.
01-11-2021 12:37 PM
@RetiredGuy wrote:Enabled roaming and that seemed to do the trick. Thanks!
Good to hear.
Welcome to Public Mobile, fellow retiree.
01-11-2021 12:35 PM
Confirmed wifi assist was toggled off. Thanks!
01-11-2021 12:34 PM
01-11-2021 12:26 PM
@will13am wrote:@RetiredGuy , I am not that familiar with iOS settings, but I do recall there being per app data settings. Can you go over all the data settings to make sure that there are no data blocks enabled. Handoff between WiFi and mobile data should be seamless and not require continual reboots to work.
@RetiredGuy...
while you're in the Settings....make sure that Wifi Assist is toggled OFF.
01-11-2021 12:21 PM
01-11-2021 12:14 PM - edited 01-11-2021 12:20 PM
Is there a Roaming button you can enable ? Try that and let us know.
edit...
