iPhone 7 Plus
LeciaroverRTK
Used an IPhone 7 Plus on Public Moblie. Sold the phone to someone else now it’s saying the iPhone is locked. How do I get the phone unlocked.
13 REPLIES 13
improper sef solution removed/solution re-assigned
LeciaroverRTK
The phone was locked by Telus. Was able to solve the problem
Hi @LitlLdy I am thinking what error OP saw.  If the phone was used here, next used on another carrier after, there is really no reason the phone got locked again.  I heard if some US carriers will lock the phone after it was used there, but no Canadian provider will do that
LitlLdy
@LeciaroverRTK , if this is a dumb question I apologize but did you erase all content & settings to restore the iPhone as new before selling it? Which removes it from your iCloud account, iTunes & so on.
Hi @LeciaroverRTK yes,  please check the blacklist first.  If the phone is clean, try to submit a ticket with PM for help.
LeciaroverRTK
I got the phone used hand back in 2017 and put it on public moblie. Then my dad used it on public moblie as well. Then we just stopped using it
Hi @LeciaroverRTK if it was used in PM, and never used on another network since, there is really no reason the phone is locked again and cannot be used here
Check blacklist first
At the same time, submit ticket with PM and explain that it was used here before and now you try to use here again and hope they can unlock for you
LeciaroverRTK
My father had it and give up on the cell phone after me. Also was on public mobile. His public account was deactivated a few months ago. So I don’t know why it would be locked
Hi @LeciaroverRTK so, it was never used on PM network before??
it would be easier to ask the buyer for help
  You can still try PM agent  but they might not help
and you sure the phone has a lock problem and not blacklisted?  check here
https://www.devicecheck.ca/check-status-device-canada/
LeciaroverRTK
The phone was unlock when I got it off someone second hand. I put in the public mobile SIM card and that was it. Now it’s locked
Hi @LeciaroverRTK you got this iPhone from Telus or PM?
 Submit ticket with PM agent and they are supposed to help you to unlock
at : https://publicmobile.ca/chatbot.
First type Forgot Login,
Meow
Did you or anybody else EVER use this phone with any other provider (Telus, etc.)?
How old is this phone?
All phones sold in Canada has to be unlocked since Dec 2017.
