iPhone 15 Pro Max Nano Sim
Mhon
I had a support chat session with the official Apple iMessage support ti finally get the "official" word on the iPhone 15 Pro Max having a physical tray for a physical Nano SIM, because i see a lot of conflicting info online about whether the iPhone 15 Pro Max has or does not have a physical tray for a Physical Nano SIM  and this is the "official " answer i got from Apple... can anyone please vouch for this answer, Please and Thank you!
14 REPLIES 14
Flameotter
@Phil_Adelphus
So the main advantage of an E-Sim is getting it right away as opposed to waiting for delivery or getting it in a brick and motor location? Or having multiple sims?
hopefully Public Mobile will be able to eventually hammer out more details and allow more functionality. Transferring e-sims seems like a great convenience but having to start new each time can be a hassle.
Thanks.
@Flameotter  Correct, see:
https://www.publicmobile.ca/en/ab/get-help/articles/esim-faqs
That's where a physical sim has an advantage.
Flameotter
@Phil_Adelphus I can't transfer my E-Sim to another device without purchasing another E-sim? Does it invalidate the previous E-sim? and if I want to transfer back I have to purchase another one?
I hope not, but I don't have much experience with E-sims.
@Flameotter  ". I have read mixed experiences with users transferring E-sims back and forth regularly"
On some carriers, including PM, you can't transfer an e-sim, you have to buy a new one each time you change phones.
Flameotter
@Mhon Thank you so grateful that you started this thread.
I probably should have checked before going ahead and acquiring a iPhone 15 Pro or Pro Max.
Not sure how smooth people have been with SIM cards, I know I have been glad that I have had the ability to switch back and forth easily when a phone is damaged our out of service. I have read mixed experiences with users transferring E-sims back and forth regularly
Check out this from the Apple website, scroll down just past the built-in apps section
https://www.apple.com/ca/iphone-15-pro/specs/
@Mhon
Yes, the Canadian version iPhone 14 & 15 will have the SIM and eSIM.
The American version will have dual eSIM. The Chinese version will have dual SIMs and eSIM.
Mhon
Thank you!
Mhon
Yes, i mentioned that i was referring to the Canadian IPhone
Thank you!
JRod
@Mhon
I can confirm. I got the iPhone 15 Pro Max on launch day and it does indeed have a physical SIM card tray along with eSIM capability. I believe it’s only the US models that are ESIM only.
It's stated in the tech specs on the Canadian Apple Store that it is nano and e-sim
Mhon
Yes, advised them that I was inquiring about the Canadian phones, Thank you!
Phil_Adelphus
Did they know you were in Canada?  Canadian version has nano sim and e-sim.
Camera4617
Only USA version is eSim only ,rest of them have physical sim + eSim
