iPhone 13 pro max- will it work?
cosulliv
I want to buy a new cell phone and was going to buy the new iPhone 13 pro max but first wanted to make sure that public supports that device. When I look at the iPhones listed as being supported by public the most recent iPhone listed is the 11. Can anyone let me know if the iPhone 13 pro max will function on the public network?
7 REPLIES 7
Imexgenie
It definitely works; however, eSim would not work unless Public has the option to activate it.
Using Sim definitely would work !  Great phone - Jealous
keithrjoyce
Great, thanks, and yes bought Canadian, the Canadian Apple store.
pkaraa
@cosulliv  good phone, as long it supports the above mentioned frequencies, it should work.
Hope you are getting the phone from Canadian vendor and with good return policy(just in case)
@cosulliv
100% working, nice choice and lovely device, good luck,
Public Mobile uses the following frequency bands:
  • 4G LTE and LTE Advanced: 700 MHz, 850 MHz, 1900 MHz and 2100 MHz downlink and 1700 MHz uplink (AWS).
  • HSPA: 850 MHz, 1900 MHz (UMTS).
enjot it...
cosulliv
Thank you!
Yes, the list is simply not up-to-date.
No worry, the iPhone 13 pro max is a great phone and will work great with this great network   🙂
 @cosulliv : The reference is not exhaustive. Yes the phone will work. Particularly if bought from a Canadian vendor.
