iPhone 13 Pro Max
keithrjoyce
Can I use the iPhone 13 Pro Max on Public Mobile?
Mark_C
You should be able to use the iPhone 13 Pro Max with Public Mobile, if it is not sim carrier locked. You can check this on your phone by clicking the settings app, then clicking "General", then "About". Scroll down and you should see "Carrier Lock", which should read "No SIM restrictions".
If your phone is carrier locked you would need to contact the provider it is locked with, to have it unlocked.
@keithrjoyce
Yes is will working with Public Mobile 100%.
visit Here link to you can check it full information about your device.
Public Mobile uses the following frequency bands:
  • 4G LTE and LTE Advanced: 700 MHz, 850 MHz, 1900 MHz and 2100 MHz downlink and 1700 MHz uplink (AWS).
  • HSPA: 850 MHz, 1900 MHz (UMTS).
nice device and Good Luck..
pkaraa
If it is North American version, global also works in some cases but depends from where you bought it.
If the frequencies match with these below then it will.
3G
850MHz, 1900MHz
4G LTE
Band12-700MHz, Band17-700MHz, Band29-700MHz, Band5-850MHz, Band4-AWS, Band2-1900MHz, Band7-2600MHz
Triguy
Yes, it is compatible with PM.
@keithrjoyce   YES, if yours is a North American version.    Many customers are using that already
.. and you got it in Canada, right?
