iOS 26 Uprade - iMessages not Activating
TheSponge
Can't get my iMessages or Facetime to activate. Been rebooting, signed out of apple ID, date/time settings etc. to no avail.
Is this on public mobiles end or what?
16 REPLIES 16
TheSponge
Bought a new eSIM and this solved my issue immediately. New eSIM, reset network settings when the phone rebooted iMessages activated.
clearly something on the public mobile end. Going to request a refund for the new eSIM.
Alikief
Having the exact same issue!! It appears to be on Public Mobile’s end. I think they need to push an update
marvin114
When i had this issue a couple of months ago (imessage not activating) purchasing a new esim solved this issue.
TheSponge
So getting a new eSim solved your issue?
marvin114
the agent helping me does not want to credit 5 dollars to me again as it was already done before a few months ago (had the same problem before and I purchased a new e-sim and credited 5 cad to me. it did solve the imessaging issue though)
Now I am stuck without imessage. I dont want to pay 5 dollars because this issue is from their end. Still waiting for them to do something to my account. Just very frustrated as from other networks, this is not happening
@TheSponge wrote:
Can I buy another eSIM with the same phone number I’m currently using?
yes, if you follow the steps in my post above, you will get to keep the phone number
TheSponge
@TheSponge wrote:
They also said my carrier should remove/re-add my e-sim to refresh my signal..
@TheSponge
you shouldn't need to do that, but let's try it, why not
you don't need to delete the old esim yet,  Just login PM app on your iPhone, buy from the Account page, Purchase Sim Card, choose eSIM.  It might say $5, complete the transaction and it should show $0 (or if it charges you, you can ask PM to reimburse)
after the new one is install, make sure you disable the old one, reset network settings and try it
TheSponge
TheSponge
Spoke with Apple their basically saying the carrier won’t authenticate the iMessage capability.. so seems like no solution..
I updated to iOS 26 last night and I couldn’t send a message to my partner by RCS messaging to an android phone on my iPhone 14 Pro Max. I had to send it by iMessage for it to work.
TheSponge
Ya no luck. They told me to call again in 24hrs..
@TheSponge wrote:
tried it all, cant get it to work.
i cant contact apple support the message won't send through their app as their imessage based texts..
@TheSponge , you can call Apple Support. I don’t know if I am allowed to post their support # but you can scroll down towards the bottom of that page & the # is there.
If you have already toggled off iMessage & FaceTime, rebooted the iPhone then toggled them back on again, then select the phone # to see if that will get it to work I don’t know any other suggestions. Sorry. I can only suggest what worked for me.
TheSponge
maddymcnab
im also having this isshe
slusagm
another post have the same issue
https://productioncommunity.publicmobile.ca/t5/Get-Support/IOS-26-update-My-phone-number-not-working...
but this is an Apple issue.  If you check internet, it is not uncommon
Try reboot phone and try again.  If still show unsuccessful, check with Apple support first.  Someone on the internet said they contacted Apple and was told the ID was blocked due to spamming.
