05-14-2024
01:34 PM
05-14-2024
03:29 PM
computergeek541
After porting my number over I was having issues with texts. Which are now working, but my IMessage is not working under my phone number and I contacted Apple and they said it’s a Public Mobile issue. I’ve tried resetting settings, removing SIM card, and hardboots. However, nothing seems to be working.
05-14-2024 03:34 PM
just tested and my iMessages are now working, although I’m not sure what has changed lol
05-14-2024 03:30 PM
Old provider is no longe option, using physical public mobile SIM and not dual SIM with eSIM
05-14-2024 03:29 PM
I have still waiting on response, opened ticket as well
05-14-2024 03:10 PM
Check your cellular settings on your iPhone point to the new provider instead of the old one.
05-14-2024 02:06 PM
@G89 yes, this is related with your SMS issue. Message support and they can resolve it quickly
05-14-2024 02:04 PM
I ported number from old provider and it says that there’s an error every time for verifying my phone number for IMessages
05-14-2024 01:44 PM
can you confirm if you activate with new number or port in number from another old provider?
For your SMS issue, PM is having problem provisioning text capability for new activations. And if you are an iPhone user, iMessage activation by phone number will also be impacted without a working SMS.
PM is working on a fix but for now, they can only resolve the issue on a case by case basis. Please open ticket with PM support by messaging CS Agent here:
05-14-2024 01:43 PM
hi @G89
Yes, if only SMS an issue, it is a PM system problem with new activation. PM is aware of the problem and can only fix the issue one account at a time.
Please submit a ticket with CS Agent by direct message:
