iMessage verifying
Paulv999999
Just got PM on Saturday , anytime someone gets a text from me they get it with my email not phone number . In the settings my iMessage phone number is “verifying” for the last 2 days,,,  I have turned off my phone. I have reset my network settings. I have turned iMessage and FaceTime on and off several times so not sure what to do. help?
2 REPLIES 2
Chalupa_Batman
Public Mobile is dealing with issues when it comes to SMS on Android and iMessages and FaceTime and such. There is no ETA of when it will be resolved. Here is their announcement.
We are aware that some of you are currently unable to successfully use iMessage and or FaceTime features,  and we understand how frustrating this can be. Our teams are working diligently to find the cause.
In the meantime, please try troubleshoot steps:
Tap Settings > General > Transfer or Reset [Device] > Reset > Reset Network Settings.
We apologize for any inconvenience this may have caused and will continue to keep you updated.
Thank you,
  • Public Mobile Team
Keep an eye on this thread as they SHOULD update it when things are fixed.
https://productioncommunity.publicmobile.ca/t5/Announcements/Open-Issue-Trouble-using-iMessage-amp-F...
fixin1
@Paulv999999 - iMessage activation is experiencing issue with PM. Please try again later and follow up here:
You can also try CS_Agent, some said it worked:
⬇️  Click the link for an Agent * ⬇️
If the link above doesn’t work correctly, please go here to create a ticket to CS_Agent: https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
* - CS_Agent will typically get back to you within 48 hours. * CS_Agents are at load due to iMessage activation issues so it may take longer than 48 hours. * They work 7 days a week from 9 AM to 10 PM EST.  You will be required to login to your Public Mobile Community Account to contact CS_Agent. Once you are finished making the ticket with CS_Agent, please ensure that you monitor for one of the agents responding back to you because they may notify you asking for some information via Private Message, in your mailbox by clicking this link here: Messages
