i cant receive calls my number is not attribute
cedrick
i cant receive calls its been 2 days and the moderator dosent anser my email
what should i do
so help please
cedrick
Alireja
@cedrick Can you make outgoing calls? how about data? Can you connect to internet?
geopublic
what should i do
so help please
cedrick
@cedrick  Did you port your number from another provider? If yes, just continue to use your old sim to make and receive calls until you hear back from the moderator.
hycm53
what should i do
so help please
cedrick
Is your account active? Try turn off your phone 30 seconds or more, then restart your phone. If still doesn't work, try the lost/stolen trick :
To report your phone stolen. Login to your account. Choose Plans and Add-on tab. Then choose Lost/Stolen Phone tab. Then choose Suspend Service tab. Logout. Wait few minutes. Login in and report your phone found. Restart your phone.
If still doesn't work, you need to contact moderator team for your problem:
