i can not make a out going call to any toll free numbers?
SG2190
i need to call urgent to couple toll free numbers but none of them are going thru...even i rebooted my iphone but didn't work
10 REPLIES 10
@SG2190 wrote:
@hairbag1 @hairbag1
I got an solution from the agent as folllows for iphone,
Please go to the Settings, Cellular, Cellular Data Options, Voice&Data. There are 3 options for networks. Usually it is set on 5G Auto. Please check the other 5G On and test, then check LTE and test.
it did work for me from switching 5G auto to 5G.
Good to know.
SG2190
@hairbag1 @hairbag1
SG2190
yes..i did reboot my phone like multiple times but it didn't work
@SG2190 wrote:
@hairbag1 @hTideGnow
i don't understand this...
i switch public mobile 4 weeks ago and i was able to dial most of the toll free numbers but problem started since yesterday and i have to call these numbers for my work.....raised the tkt and agent added 500 min and told me to restart my phone but it didn't work and now i'm waiting for response for next step but this is frustrating as i have to chase public mobile while i'm working....
You don't need to by any add-ons...your plan should be able to dial those numbers. Did you try shutting down cell and rebooting ?
Try network rest.
SG2190
@SG2190 wrote:
800 463 3339
1 (800) 742-5877
@SG2190
I also, was able to dial both those numbers and I'm in BC. Did you have any luck calling ?
hi @SG2190 I am able to call both numbers
try Reboot phone again and then click Reset Network Settings on the phone and try once again
if same, submit ticket as said above
SG2190
1 (800) 742-5877
hi @SG2190 is that Canadian 1800 numbers? not all 1800 can be called from Canada
can you share the numbers for us to try?
if you are sure you should be able to call , ask PM agent to check
please submit a ticket with CS Agent using this Chatbot link: https://widget.telus.tiia.ai/publicmobile/publicmobile.html Type the question "Submit ticket", Then click the following in order: "Contact Us" , "Other", "Log In".
If any issue with ticket submission, you can submit by direct message:        https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
hairbag1
@SG2190
some toll frees won't connect due to regional settings on their end. You could try asking Operator to help
added...that won't work as no longer have access to traditional Operator with PM.
