11-26-2019 10:03 PM - edited 01-05-2022 08:09 AM
https://selfserve.publicmobile.ca/ only white blank screen
i tried 2 different browser + 1 just installed - only white blank screen
tried on 3 different phones - only white blank screen
tried on LTE - only white blank screen
11-26-2019 10:36 PM
I have a similar issue when signing in using Chrome. But when I switched to Chrome New Incognito window (Ctrl+Shift+N), I am able to log in to my self-serve account. Try the Chrome Incognito to see if this works for you.
11-26-2019
10:34 PM
12-06-2019
03:03 PM
Luddite
thanks - worked in incognito mode
[Marked a solution ...... Luddite; though new window seems helpful too]
11-26-2019 10:29 PM
Working fine here in all browsers i have installed.
11-26-2019 10:17 PM
I tried earlier in privacy mode with Safari and it worked. However, when I tried right now, it did not work.
Probably a gliche in the system. Maybe wait one hour and try again.
