how to restore the default greeting setting
publicy
Dial 1, can't find an option for the default greeting setting
waternlava
Dial 1; press 3; press 1; press 4
PAULRANG18
The voicemail menu will offer different options and you should delete your recorded message. Then enable the default option.
NDesai
@publicy Have a look in this KB article: https://productioncommunity.publicmobile.ca/t5/Knowledge-Base/How-To-Use-Your-Phone-and-Plan-Feature...
Ed404
The system will list options and then you dial numbers accordingly.
