how to reset active greetings
04-10-2018 09:54 PM - edited 01-04-2022 04:04 PM
04-11-2018 10:22 PM
The guide is relevant because the Voicemail operates the same regardless of what kind of phone you call it from.
04-11-2018 10:25 AM
@Korth wrote:
This guide is irrelevant since it is for Home Phone. Good try though!
04-11-2018 01:35 AM
04-10-2018 11:03 PM
@ashhaq wrote:System Greeting- 6
seems public mobile does not have option to delete/ replace the active greeting.
After you record your personal greeting, you would be able to choose between greetings, then option to choose System Greeting becomes available.
04-10-2018 10:51 PM - edited 04-10-2018 10:52 PM
@ashhaq wrote:Delete a Greeting- 4
It is available, but first you need to activate / record your personal greeting, then that option would be available.
04-10-2018 10:41 PM
i checked the telus link regarding voicemail, but public mobile lacking last 2 options out of 5 options under personal Greetings in telus
Activate a Greeting- 1
Listen to Greetings- 2
Record a Greeting- 3
System Greeting- 6
04-10-2018 10:25 PM - edited 04-10-2018 10:39 PM
@ashhaq TELUS Voicemail Quick Reference Guide: click here
04-10-2018 10:16 PM
thanks for the reply, but the issue is i am able to change/ delete the personal greeting but not the active greeting which i recorded earlier.
04-10-2018 10:07 PM
I think this is the procedure you need.
- From the handset, dial 1+ the 10-digit phone number + Send.
or - From a landline, dial the 10-digit phone number and press the star key to interrupt the system greeting
- Enter password when prompted
- Press 3 for Greetings options
- Press 1 for Personal Greetings options
