08-09-2019 03:42 AM - edited 01-05-2022 08:31 AM
Hi
l just want to ask , when is appropriate for me to change change my plan?.
Thanks.
Service
08-09-2019 05:25 AM
@bola2310You can change your plan any time you like. Just be aware that once you change your plan, your plan date resets and the rest of your prepaid plan that you had paid before will be forfeited.
08-09-2019 04:22 AM
@bola2310 you can log in and go in change plan and then it will ask you if you want it done now or on next renewal! I would suggest next renewal because if you select now you will loose the remainder of your paid month and will have to pay the full amount for the new plan starting right now.
