06-20-2022
10:40 AM
06-20-2022
05:58 PM
computergeek541
06-20-2022 11:00 AM
@heatherjg wrote:i would like to change email address on my account..through private message
HI @heatherjg best is to open ticket with Chatbot
at : https://publicmobile.ca/chatbot. Follow this to get to ticket open screen quicker:
Once ticket is submitted, make sure to check your Community Inbox(top right corner envelope icon) periodically for response from PM's CS Agent
06-20-2022 10:57 AM
06-20-2022 10:50 AM
06-20-2022 10:46 AM
The only way to change your email address on your account is by a CS_Agent through private message or create a ticket by SIMon Chatbot on this Community page.
If you want to change your email on this Community page, click on your avatar on the top right of this page.
06-20-2022 10:43 AM
If you mean the account login then you can use that simply as the login. If you need to change the password and you no longer have access to that email inbox then you would need the support people to change it for you.
If you mean the community account, you can do that yourself in the my settings under your hamburger avatar.
06-20-2022 10:43 AM - edited 06-20-2022 11:07 AM
@heatherjg you will need to open a ticket, to speak to a customer service agent Click here or if you are having issues with Simon you can send private message to a CS Agent here: https://bit.ly/2GGCJzH
