02-28-2023
03:02 PM
02-28-2023
07:40 PM
computergeek541
I submitted a post this morning, but it doesn't appear anywhere. Where can |I find it? I clicked on the mail icon, but it only showed posts from 2022 and 2020.
03-01-2023 10:06 AM
@Jradke wrote:It was rejected??? All I asked is if I changed plans would I lose my one time bonus and other holiday giveaway bonus? But I added details including my current plan $25/month and the plan I wish to change to, $35/month. Why was this rejected?
@Jradke - most of us have been hit with rejected posts without knowing why they were sent this direction. Don't feel you are the only one. 🙂
02-28-2023 05:46 PM - edited 02-28-2023 05:48 PM
@Jradke so, you found your posts there? sometimes, sequence of number would trigger it, it probably thinks it is phone number or account number
To answer your question, NO , you won't loss your one time bonus like those data and LD bonus from December. Only thing you will lose are those activation bonus like the 2 GB bonus for xx months, it is those showing under My Promotion section in My Account. If you don't have any, then no worry and go ahead with plan change
02-28-2023 05:35 PM
02-28-2023 04:27 PM
@Jradke check if you see the posts here, it could be trapped by the spam filter :
https://productioncommunity.publicmobile.ca/t5/premod/moderationitemspage/tab/rejected
02-28-2023 04:25 PM
I have 5 posts, but none from today, nor do I see anything in draft form.
02-28-2023 03:14 PM - edited 02-28-2023 03:15 PM
It’s possible, the post is still sitting in draft form.
Under your avatar, when you click under your my profile, then look near the bottom of the page, you should see any posts that are still in draft and not submitted to the community page.
02-28-2023 03:05 PM
@Jradke , click on your avatar on the upper right corner of the web page and select my profile. You should see post information there.
