help
Enida
I tried to activate my eSIM, but then it didn’t work when I tried to login again it asked me digit code from the number that it didn’t work to activate
1 REPLY 1
hi @Enida
you were using app to subscribe??
Check sim manager on your phone or Settings -> Cellular and check if the PM eSIM is there, enable it
if still have problem, please message support agent here
